jrswanson91
Oct 15, 2015Aspirant
WNDR3400v2+WN2500RPv2 Port Forwarding
I hope someone can help, I am trying to establish port forwarding to my home server from outside my LAN. I have the WNDR3400v2 router with the WN2500RPv2 extender connected to it. I am trying to esta...
- Oct 29, 2015
Thank you for all your help, I have solved this problem. FINALLY! The problem was my firewall and anti-virus. Once I provided rules to accept all incoming traffic and turned off my antivirus, all works well! That was very grueling and time consuming. The portforwarding works from the modem to the router through the extender to the pc and it works.
Thank you again for trying to help.
ElaineM
Oct 28, 2015NETGEAR Employee Retired
That's right. This should be working first through the modem.
If this can't be done through the modem then it will not work either with the router.
jrswanson91
Oct 29, 2015Aspirant
