GeoHead
Mar 21, 2019Initiate
WNDR3400v3 - firmware update to v1.0.1.24
I did a firmware update last night and all appeared to be fine until I went to my iphone & ipad to access WiFi. The network shows as it always has but it doesn't like my password on either device, ev...
- Mar 21, 2019
> [...] I've tried rebooting my unit but there's no change. [...]
The next step would be a settings reset.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Factory Settings"
(or "reset").Restoring old saved settings could restore the old problem(s), too,
so a manual reconfiguration will be required after the reset.
antinode
Mar 21, 2019Guru
(or "reset").
GeoHead
I tried the reset button on the back and that didn't work. I then went to the manual as suggested and found how to erase it back to original settings and that did the trick.I'm back in business.....Thanks !!!!
- antinodeMar 21, 2019Guru
> I tried the reset button on the back and that didn't work. [...]
"tried" how, exactly? Used according to the instructions in the User
Manual, it should.> [...] I then went to the manual as suggested and found how to erase it
> back to original settings [...]How was that?
> [...] I'm back in business [...]
Thanks for the report. (What could go wrong?)
