Phlegmbot
Dec 26, 2021Aspirant
WNDR3400v3 - wireless devices connect to network but internet not working; intermittent issue
Hardware Version WNDR3400v3 Firmware Version V1.0.1.42_1.0.68 GUI Language Version V1.0.1.24_2.1.28.1 When I first set this router up it worked great, but then started getting inter...
wcalifas
Dec 27, 2021Prodigy
I agree, it might be time to upgrade to a newer router. You can use that one as an access point, that's what I do with my older slower routers.
michaelkenward
Dec 27, 2021Guru - Experienced User
Good call, but only if you are desperate to fill "not spots". The wifi on that aged router ain't gerat.
