mikigolf
Nov 18, 2015Aspirant
WNDR3400v3 - wireless does not work
Bought in August 2015. Now after 90 days Was working fine until two days ago.
It works when I hook up the ethernet cable so it is not the internet connection.
I tried going into control pane...
mikigolf
It appears that problem may be with the PC network adaptor. I checked device manager and Realtec is yellow. Download a new drive but not sure it it installed. I get the following message
Driver Management concluded the process to install driver netrtwlane.inf_amd64_0c38440cd4a5a694\netrtwlane.inf for Device Instance ID PCI\VEN_10EC&DEV_8723&SUBSYS_072410EC&REV_00\4&2EEAE01&0&00E1 with the following status: 0x17.
Also
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
I did a system restore back to Nov 14 but this did not work.
I can connect wirelessly with my ipad and all the lights on the router are working. I also checked the airplane mode to verify it was not turned on.
Perhaps, I may need to take my computer in for service.
michaelkenward
Nov 19, 2015Guru - Experienced User
The PC network adaptor deals with the LAN (wired) connection. Something else usually handles the wifi. Or is this network adaptor the wifi card in your PC?
One way to deal with driver issues is to remove all of the drivers in Device Manager, reboot the PC and let it find the drivers afresh.
Another option, have you visited the motherboard maker's website for new "chipset" drivers. These don't always show up in Windows update.
Then again, I am not sure what problem you are trying to solve.
The PC's wifi behaviour, and its drivers, will have no effect on the interaction between the WNDR3400 and a laptop.
Can you get at the web interface for the WNDR3400v3 using the LAN? If so, that should let you get into the WNDR3400 so that you can investigate the wifi settings.
- mikigolfNov 20, 2015Aspirant
In device manager, there are two adapters one for LAN and one for wireless. The wireless indicator is yellow. I tried a download but this did not help. Genie indicates there is a problem with the wireless. .
I can connect with an ethernet cable but can not see the wireless networknor can I wirelessly connect. My Ipad works with the wireless.
I did go into router log in. The wireless setting appear to be correct.
I can only sumise that the problem is with the adapter.
Motherboard-Excuse my ignorance, but I have Intel Core I7 on a Toshibal Laptop S855.
Should I go to this website.
Issues found iT APPEARS THAT I MUST UNINSTALL THE DRIVER AND REINSTALL. THE DOWNLOAD DI D NOT WORK. I WILL HAVE TO GO TO INTEL? Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC has a driver problemThere is a problem with the driver for Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC. The driver needs to be reinstalled.Not fixed
Reinstall device driverCompletedHardware changes might not have been detectedDetected
Scan for recent hardware changesCompletedPotential issues that were checked Windows Update configured to never install driversDriver updates aren't automatically installed when detected by Windows Update.Issue not presentIssues foundDetection details 6Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC has a driver problem Not fixed
Device informationName: ID: Error code: Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC PCI\VEN_10EC&DEV_8723&SUBSYS_072410EC&REV_00\4&2EEAE01&0&00E1 39 Reinstall device driver CompletedThere is a problem with the driver for Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC. Reinstalling the driver might fix this problem.6Hardware changes might not have been detected Detected
Scan for recent hardware changes CompletedScanning might find new devices attached to your computer and install them.Potential issues that were checkedDetection details Windows Update configured to never install drivers Issue not presentDriver updates aren't automatically installed when detected by Windows Update.Detection details- ElaineMNov 23, 2015NETGEAR Employee Retired
mikigolf Were you able to update the driver of your computer?
- mikigolfNov 23, 2015Aspirant
I will next try deleting the driver. Also, I have another computer that shows connected to netgear but I cannot connect to the internet. Microsoft indicates that another computer is using the same IP address. How do I change the IP address for that compter
