mikigolf
Nov 18, 2015Aspirant
WNDR3400v3 - wireless does not work
Bought in August 2015. Now after 90 days Was working fine until two days ago.
It works when I hook up the ethernet cable so it is not the internet connection.
I tried going into control pane...
mikigolf
Nov 24, 2015Aspirant
Decided to go to web and search for my Realtek driver. Found it and downloaded the new driver, which fixed the driver problem. Then I was able to see the wireless network.
Still could not connect, but removed access control and went into genie. Finally able to connect.
Thanks for all your help. After 35 years, sometimes I manage to find a solution
Would still like to set up my other computer. It works outside of my home but I can not connect to the internet without the wire.
ElaineM
Nov 24, 2015NETGEAR Employee Retired
Thank you for the update!
Good to hear that you're connected now.
Have a great day!
