MaxHP
Apr 01, 2017Aspirant
WNDR3400V3 2.4 G WiFi Disconnecting HELP
I have 3 netgear products CM700 Cable Modem WNDR3400V3 Wireless Router and WAC104 Wireless Access Point. When I set the WNDR 2.4 G all me devices drop on 2.4 G and reconnect at least 1 time per minu...
- May 24, 2017
Well I gave up the only way to stabilize this router was to disable the radio and that isnt an option. I purchased a new R6700v2 router and set it up now my system is stable on all devices. I have all 12 Cat5e devices wired and 5 2.4gHz older androids set and 6 5gHz devices all running without issue. I would like to return this WMDR3400V3 but I suppose I have little chance of that.
Thanks for the help and short of opening up the device I believe I tried everything to get it to function as it should.
MaxHP
May 24, 2017Aspirant
