Jason32038
Jul 09, 2017Aspirant
Wndr3400v3 2.4g and guest problem
So I was changing some settings for qos and wmm and also disabled my guest network for 2.4g. Our phones wouldnt connect to wifi after so I went back and changed every setting back until I narrowed it ...
ElaineM
Jul 20, 2017NETGEAR Employee Retired
By the way, are you connecting to the Guest network or the main wireless network?
How about if you remove the profile from your phone and reconnect to the wireless network?
ElaineM
Jul 21, 2017NETGEAR Employee Retired
You may also want to make sure that you have the latest firmware installed on your router.
The firmware can be downloaded here.
After updating the firmware, reset the unit and reconfigure it.
- Jason32038Jul 22, 2017AspirantThe factory reset worked. Thank you for the help!
