MCHooft
Oct 26, 2016Aspirant
WNDR3400v3 blocking email & can't do factory reset
Hi there, One of my email accounts was compromised and now my netgear router is blocking this account (can't download/send email from Outlook, can't go to webmail online). I have tried to do a ...
- Oct 27, 2016
Time to get a new one.
ElaineM
Oct 27, 2016NETGEAR Employee Retired
Hello MCHooft
Welcome to the community!
Do a factory reset then reconfigure the router to get the Internet connection back.
If the factory reset steps didn't help, try the steps below.
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
- MCHooftOct 27, 2016Aspirant
Thanks for the advice! I did manage to do some sort of reset, but it doesn't seem to be a full reset as it is still using my old password and blocking my email. What else can I do?
- ElaineMOct 27, 2016NETGEAR Employee Retired
Did you follow the other reset instruction?
That should fully reset the unit and should not use your old password.
Hi Elaine,
I did follow your 1, 2, 3 instructions and from that it seemed like some sort of re-set was in process, but then the internet came back on and nothing had changed (still blocking my email website and not able to download/send emails from my Outlook for that specific account). I was told by my email service provider that without totally re-seting the router I won't be able to use my email. I don't think a full factory re-set has happened (or maybe I'm wrong and it just didn't work). I'm not sure what else to do or why this one website is being blocked. We had also tried disabling the Port Scan (assuming this was a DoS attack or problem).
Any other thoughts? Or do I just have to get a new router?
