weswiliamsjr
Mar 27, 2016Aspirant
WNDR3400v3 dual band - devices not connecting to 2.4ghz with passcode off
I have the router WNDR3400v3 and up until last night my 2.4ghz internet was working with one of my laptops connected to it, now nothing can connect to it. My router Firmware Version is V1.0.1.4_1.0.5...
- Aug 08, 2016
reset the router by holding down the power button and that fixed everything
Mslady44109
Mar 29, 2016Aspirant
Yes! I do. I'm sorry for the delay in response.
ElaineM
Mar 30, 2016NETGEAR Employee Retired
Did you try other security? Will it exhibit the same issue?
If yes, kindly rollback your firmware to version 1.0.1.2.
Once done, reset the router and reconfigure it to get back the connection.
Let me know what happens.
- weswiliamsjrApr 04, 2016Aspirant
Sorry for the delayed response, but I tried other security and yes, it exhibits the same issue. How do I rollback the firmware on the router.
Rolled the router back to Firmware Version 1.0.1.2 and performed a factory reset, that fixed the problem
- ElaineMApr 05, 2016NETGEAR Employee Retired
Let me check with our engineering team on how to proceed on this.
