JoylessFire
Apr 27, 2016Aspirant
WNDR3400v3: ps4 nat 3
I DO NOT HAVE THAT MODEL!!!! I HAVE A WNDR3400V3 WIFI ROUTER, BUT IT IS NOT LISTED AS A MODEL TO CHOOSE
Firmware Version V1.0.1.4_1.0.52
I have the most recent firmware that i'm aware o...
- Apr 29, 2016
Checked my most recent bill from them and they haven't been charging me for one, even though i asked specifically for one... I'll contact them when they're open and hopefully get it fixed
TheEther
Apr 28, 2016Guru
Is your ISP box a modem or combination modem/router?
JoylessFire
Apr 29, 2016Aspirant
From what i know, its a combo router + modem
- TheEtherApr 29, 2016Guru
Then you will need to either put it into bridge mode or equivalent such that your WNDR4700 receives a public IP address. Or convert your WNDR4700 into an Access Point. Or set up port forwarding on both the combo router + modem and the WNDR4700.
- JoylessFireApr 29, 2016Aspirant
I only have the one router/modem combo device. My ISP helped me set it up so that its modem to them, and router to me
