DERoss
Feb 11, 2021Apprentice
WNDR3400v3 Remains Active for a Shut Down PC
Netgear N600 Wireless Dual Band Router Model WNDR3400v3 When I shut down my PC, the router's LAN port LED for my connection turns amber. The User Manual says that this means there is still a 1...
antinode
Feb 11, 2021Guru
> Why does a link remain active between the router and a shut-down PC?
Because your "a shut-down PC" keeps its Ethernet interface active,
even when you think that it is "shut-down".
> Is this not a security issue?
Typically not. If it worries you, then you'd need to use a real
power switch, or disable the Ethernet interface in stand-by mode in the
computer's firmware/BIOS, or use your (unspecified) "a small
application".
The primary value of using the computer's stand-by power supply to
power its Ethernet adapter is to enable a feature called Wake-on-LAN.
https://en.wikipedia.org/wiki/Wake-on-LAN
If you don't want it, then you should be able to disable it.
> My PC: Windows 7 Ultimate SP1 x64
> My wife's PC: Windows XP SP3
The OS is less important than the hardware (and its associated
firmware/BIOS).
> [...] I saw that someone else had a similar question [...]
Thanks for the helpful link.
DERoss
Feb 14, 2021Apprentice
On my wife's PC, I finally solved this problem. Besides disabiling Wake-on-LAN (WoL) in BIOS, I had to go to the Control Panel, where I had to disable several WoL capabilities. Now, when her PC is shut down, the router's LAN port LED for that PC goes out, not amber.
