DERoss
Oct 31, 2023Apprentice
WNDR3400v3 Shows Connection for Shutdown PC
I have a LAN through a Netgeer router (WNDR3400v3). The LAN has two PCs connected via Ethernet cables. The cables are connected to ports 2 and 4 on the router. Why does the router show port 4 ...
- Oct 31, 2023Maybe because PCI Wakeup or WoL is enabled in the BIOS?
(PS: your router is ancient. Better upgrade to current standards)
microchip8
Oct 31, 2023Master
- DERossNov 02, 2023Apprentice
That is it! I had tried an application to wake my wife's PC from mine and mine from hers. It never really worked as I wished, so I deleted it. I forgot to turn off Wakeup in my BIOS.
Thanks.
