tenjay
Feb 11, 2017Aspirant
WNDR3400v3 unable to connect to network switch FS608
I'm hoping for help setting up my home network with router configurations rather than buying new equipment. Any help is appreciated! I had everything working great until my old Netgear RP614 rout...
- Mar 02, 2017
I'm embarassed to say that it turned out to be the cat5 cable I had running between my router and network switch that was causing the issue. I replaced it (pulled a new cable through the wall) and everything worked again. I'm not sure how the previous cable was damaged, but that turned out to be the issue.
ElaineM
Feb 13, 2017NETGEAR Employee Retired
Welcome to the community, tenjay
Where is the FS608 connected to the WNDR3400? Which port?
Check if you have a light on the router.
If you you do not get a light on the port, connect a computer directly to that port and see if it will lit and get online.
Another thing you may do is to try a different port on the router.
- tenjayMar 02, 2017Aspirant
- William10aMar 02, 2017Master
Not the first time a bad lan cable has happen just one pair bad in a lan cable will keep a 1gb connection from working.
A lan cable test comes in handy try running a 120 foot only to find another person cut the cable in the middle after the sheet rock is up.
