tenjay
Feb 11, 2017Aspirant
WNDR3400v3 unable to connect to network switch FS608
I'm hoping for help setting up my home network with router configurations rather than buying new equipment. Any help is appreciated! I had everything working great until my old Netgear RP614 rout...
- Mar 02, 2017
I'm embarassed to say that it turned out to be the cat5 cable I had running between my router and network switch that was causing the issue. I replaced it (pulled a new cable through the wall) and everything worked again. I'm not sure how the previous cable was damaged, but that turned out to be the issue.
William10a
Feb 20, 2017Master
Have you tried to reset the devices in the living room back up when replaced the router you change lan settings to your devices from your posting you replaced the router no other changes to the network.
