tenjay's avatar
tenjay
WNDR3400v3 unable to connect to network switch FS608
I'm hoping for help setting up my home network with router configurations rather than buying new equipment. Any help is appreciated!   I had everything working great until my old Netgear RP614 rout...
  • tenjay's avatar
    tenjay
    Mar 02, 2017
    I'm embarassed to say that it turned out to be the cat5 cable I had running between my router and network switch that was causing the issue. I replaced it (pulled a new cable through the wall) and everything worked again. I'm not sure how the previous cable was damaged, but that turned out to be the issue.
