barrosapo
Mar 09, 2023Aspirant
[WNDR3400v3] Wireless Isolation enabled prevents devices access to Internet
Here is the setup that I'm troubleshooting: Model: WNDR3400v3 Firmware version: v1.0.1.42_1.0.68 AP mode: On Get IP address dynamically: On Get DNS server address dynamically: On Recently...
- Mar 10, 2023
barrosapo wrote:
I wonder if the WNDR3400v3 creates some sort of ACL that blocks inbound/outbound traffic to all, except DHCP to the router. In Advanced > Security > Access Control, it shows all connected devices as allowed. Is wireless isolation supposed to be meant when WNDR3400v3 acts as the router?
That device dates back to 2014, based on a model from 2010.
It predates many of the things that you will find in newer routers.
"Wireless Isolation" is no longer something that you will find mentioned for most Netgear devices sold in the past decade.
According to Netgear's manual for your device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
This might also be worth reading:Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
michaelkenward
Mar 10, 2023Guru - Experienced User
barrosapo
Mar 12, 2023Aspirant
Thank you for providing the link to the document. đ
Which features are disabled on my NETGEAR router when it is set to AP Mode
The following features are not available (grayed out) when your NETGEAR router is in AP mode:
Guest Network
As for your advice about the equipment, I'll bring that up to the owner of the equipment. đ
