WilliamBonnie
Jan 01, 2016Aspirant
WNDR3400v3 wps flashing on its own
I looked but couldn't find anything similiar. I woke up other day and my wps light was flashing green on its own. It sits above everything on wall elevated so I cam see it from my room and it was not ...
- Jan 05, 2016I guess I'll replace it sometime in near future. Didn't last long. I was thinking issue with hardware. Past it's warrenty time but gives me opportunity to get a higher signal and better netgear router with more features.
WilliamBonnie
Jan 02, 2016Aspirant
Negative no accidental press. 2 of them aren't but the new 3rd is younger college kid. They have so many coming and going from there. It was very strange. I was thinking if it was the 3rd guy he had help as he seems dingy. Hard to say. For sure the first 2 are not smart. 3rd may but it was that one time and I also notice now a wifi ssid coming from there place with name. Whether or not they are actively broadcasting a Internet signal idk but there is a ssid signal with name. I check my logs and it isnt showing anyone else on it but me with 1 device currently.
- wcalifas831Jan 03, 2016Prodigy
You should then do a hard reset of your router to factory state and re-do your settings with a different password and better security to your password. Which security did you use for your password (e.g. Wpa-tkip, wpa2-aes?)
