jenom
Feb 20, 2018Follower
WNDR3500 VOIP Blocking
I have a WNDR3500 router, and a VOIP box connected to one of it's LAN port
Interestingly, incoming phone calls are working fine, however outgoing phone calls are blocked .
My VOIP box works fine when used with another router.
Any suggestion what to change in WNDR settings ?
Thanks!
Hi jenom,
1. you may try contacting the VOIP box manufacturer to check if there are ports that need to be forwarded.
2. If there are, you can do Adress Reservation for the VOIP box then forward the ports. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi jenom,
Dexter
Community Team
