JoakimSwe
Jul 06, 2016Aspirant
WNDR3700 and Samsung TV: wifi but no Internet
Hi I just bought a Samsung smart TV and am now trying to connect it to the internet via wifi. The problem is that it connects to the router but not to the internet. Other things that DO give an ...
- Retired_MemberJul 07, 2016
I don't think you have a choice other than a reset to defaults,
try setting up a guest network without security to see if works, then try different security settings
Retired_Member
Jul 07, 2016I don't think you have a choice other than a reset to defaults,
- JoakimSweJul 10, 2016Aspirant
I ended up doing a reset of the settings. And it works!
I can't beleive it... Right now I have the exact same settings as I had before resetting. Really strange.
But I'm glad it works :)
