MisterDWO
Dec 28, 2020Aspirant
WNDR3700 Base Router (No Version # On Unit)-Random Internet Connection Drops
The current firmware version installed is V1.0.7.98NA. My internet connection randomly drops 2 - 3 times a day. My ISP is TDS. I have an Arris SB6141 cable modem. If I exclude the router and connect ...
Dec 29, 2020Guru - Experienced User
Have you tried re-installing the firmware to the router? Try re-installing the firmware, then do a factory reset and clean install (by clean, just don't use a backup configuration).
If that doesn't help, I'd actually look at updating the router. it was made in 2009.
MisterDWO
Dec 29, 2020Aspirant
There is no firmware available on the Netgear support web page for the base WNDR3750 router.. Is it okay to use the one for WNDR3700-V1 since it is the same version as the firmware currently installed?
- plemansDec 29, 2020Guru - Experienced User
I don't see a wndr3750 at all.
What actual wndr do you have and what version is it?
You don't want to use a firmware that isn't matching for it as it could have different hardware between versions.
- MisterDWODec 29, 2020Aspirant
Sorry for the typo, it is a WNDR3700 base model.
as long as there's nothing after the model number it should be a v1.
try reinstalling that firmware to it .
