MisterDWO
Dec 28, 2020Aspirant
WNDR3700 Base Router (No Version # On Unit)-Random Internet Connection Drops
The current firmware version installed is V1.0.7.98NA. My internet connection randomly drops 2 - 3 times a day. My ISP is TDS. I have an Arris SB6141 cable modem. If I exclude the router and connect ...
MisterDWO
Dec 29, 2020Aspirant
There is no firmware available on the Netgear support web page for the base WNDR3750 router.. Is it okay to use the one for WNDR3700-V1 since it is the same version as the firmware currently installed?
Dec 29, 2020Guru - Experienced User
I don't see a wndr3750 at all.
What actual wndr do you have and what version is it?
You don't want to use a firmware that isn't matching for it as it could have different hardware between versions.
