po90260
Oct 03, 2021Aspirant
WNDR3700 changing from wireless to wired (radio off)
Need to know how to switch back and forth from wireless to wired and back using a wired only PC running Win 7.
Oct 04, 2021Guru - Experienced User
did you push and hold it for 2 seconds?
po90260
Oct 05, 2021Aspirant
Holding the wifi button 2 seconds appears to toggle it on and off (I looked for wifi signals using my phone). There is no on/off led light directly beneath the wifi button. Very misleading! It causes the WPS light to go on and off. I don't know much about WPS and whether I even need it. The only wifi devices that I use are the Firestick and to sometimes get data for my phone. Will the wifi toggle on and off if I'm not using WPS?
Thanks
- plemansOct 06, 2021Guru - Experienced User
it should
- po90260Oct 07, 2021Aspirant
OK, I'll play around will wps
but
I still can't login to my router using www.routerlogin.com or 192.168.1.1 on my wired PC.
- plemansOct 08, 2021Guru - Experienced User
what modem/gateway is it connected to?
Have you checked to see what its IP address is?
