Lcarey596
Nov 07, 2020Aspirant
WNDR3700 Router Problems
The WNDR3700v1 router worked yesterday and today I can't even sign-on to it. I turned everything off and rebooted the modem, rebooted the router, rebooted the computer. still no internet. Then I no...
antinode
Nov 07, 2020Guru
> it.
Perhaps it (or its power adapter) failed.
> [...] didn't work. [...]
Not a very detailed problem description.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the Setup Manual and/or User Manual. Read.
Look for the LED descriptions and "Troubleshoot".
> Then I tried to sign-on to the router with the 192.168.1.1 and the
> computer kept telling me no, that it can't find it.
What's the IP address of your computer when you do that?
> What is going on? [...]
With my weak psychic powers, describing _that_ is _your_ job.
Lcarey596
Nov 24, 2020Aspirant
Wave Broadband came out to check everything and also looked at the modem, and it was Okay.
They said it was my router that died!đ
Thanks
- wcalifasNov 26, 2020Prodigy
You can try another power adapter of the same voltage and see if it was that. If you say you couldn't log into it maybe it has died. You can log into it by connecting your laptop to one of the 4 LAN ports on the back, on your browser either type 192.168.1.1 or http://routerlogin.net. The user is admin and the password is password. Let us know what happens so we can further help you.
