Lcarey596
Nov 07, 2020Aspirant
WNDR3700 Router Problems
The WNDR3700v1 router worked yesterday and today I can't even sign-on to it. I turned everything off and rebooted the modem, rebooted the router, rebooted the computer. still no internet. Then I no...
Lcarey596
Nov 24, 2020Aspirant
Wave Broadband came out to check everything and also looked at the modem, and it was Okay.
They said it was my router that died!đ
Thanks
wcalifas
Nov 26, 2020Prodigy
You can try another power adapter of the same voltage and see if it was that. If you say you couldn't log into it maybe it has died. You can log into it by connecting your laptop to one of the 4 LAN ports on the back, on your browser either type 192.168.1.1 or http://routerlogin.net. The user is admin and the password is password. Let us know what happens so we can further help you.
