rubble
Feb 22, 2022Tutor
WNDR3700 suddenly slower
After many tears of good service to the far-flung corners of my house, my WNDR3700 has suddenly slowed to a crawl. If I put a Wi-Fi computer right next to the router the signal is strong, but it dro...
Feb 22, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute then back ON.
- rubbleFeb 22, 2022Tutor
The firmware is V1.0.7.98NA. The modem is a Arris (Optimum) TM822. I believe that no factory reset has been done since the original installation. Pulling the power on the moden didn't help. Thanks.
- FURRYe38Feb 22, 2022Guru - Experienced User
Last resort would be a factory reset and setup from scratch.
Thanks for your suggestions. I think I have found the problem. There Is a hidden router channel that mimics the main channel and slows it down. i was able to change the main channel on the router and it sped up dramatically. However the hidden channel jumped to the new channel and the router once again slowed down. the question is how I can rid the hidden channel from the router, or keep it from changing on its own?
What do you mean about this hidden channel?
Do you have a screen capture?
Do you have any repeaters or extenders running?
Any wifi nieghbors near by?
What happens if you change the SSID name and password to something different temporarily?
- wcalifasFeb 23, 2022Prodigy
When you say hidden channel do you mean someone else's wifi on the same channel as your router?
