rubble
Feb 22, 2022Tutor
WNDR3700 suddenly slower
After many tears of good service to the far-flung corners of my house, my WNDR3700 has suddenly slowed to a crawl. If I put a Wi-Fi computer right next to the router the signal is strong, but it dro...
Feb 22, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute then back ON.
rubble
Feb 22, 2022Tutor
The firmware is V1.0.7.98NA. The modem is a Arris (Optimum) TM822. I believe that no factory reset has been done since the original installation. Pulling the power on the moden didn't help. Thanks.
- FURRYe38Feb 22, 2022Guru - Experienced User
Last resort would be a factory reset and setup from scratch.
