and0r
Aug 05, 2015Aspirant
WNDR3700 throughput
Hi, What's the normal throughput for a WNDR3700v2? I'm testing throughput via local FTP and im only achieving a maximum of 10MB/s (megabytes), and 10MB/s is roughly 80mbit per second. Is this n...
Daenerys
Aug 05, 2015Luminary
The actual throughput will vary. There are several factors that could reduce the throughput like interference, distance, load, speed of the CPU, packet size, traffic distribution, etc. Throughput and bandwidth are just the theoretical maximum but not the guaranteed performance.
and0r
Humm, thanks for the reply but everything is optimal
And there is a pretty large difference between theoretical 300mbps and real world 80mpbs performance
I've never owned N hardware and I can't find real world numbers on what the actual thuroughput should be. So it's all a mystery to me.
- and0rAug 05, 2015Aspirant
Thanks
It looks like my numbers are normal, but the chart doesn't specify weather its measuring in mbit or mbyte. I will assume mbit.
And I don't understand why the term "300mbit" is marketed so much when nothing realistically achieves this type of throughput.
- netwrksAug 05, 2015Master
It says Mbps. You can click on the charts, they expand for a better view.
