Goombahz's avatar
Goombahz
WNDR3700 v1 firmware 1.0.16.98NA no LOGIN access
I've had this router for 6yrs and always found uses and solutions for it but this time I'm baffled.  Following an ISP change I upgraded the firmware to 1.0.16.98NA as I was having the regular hang is...
  • Retired_Member's avatar
    Retired_Member
    Feb 25, 2016
    That router was one of the 1st dual band routers and had several problems. I had two, as for AP they never worked correctly. When I moved last year I junked them and 2 wndr4000.
    There was a beta AP mode version. Also the correct way to reset that router is to Hold reset until power led flashes otherwise some settings are not wiped.
