Joslinm's avatar
Joslinm
wndr3700 very slow wifi
Seems all of a sudden my wireless is quite slow and weak. I get download speeds of 60 mbps wired to the desktop through the router, but only about 10 with wifi. Router is 2 ft away. I looked in the...
  • Joslinm's avatar
    Joslinm
    Apr 04, 2016
    I was doing download speed testing using Road Runners Residential speed test. Got only 10mbps wireless compared to 60 wired
    This is a problem that happenned all of a sudden.
    Did a reset and still poor wireless. Tried changing channels a couple times as suggested on various sites. No effect at all. Cell phones would barely connect only 3 ft away from the modem. I think it just wore out
    Bought a new WNDR4300 and works perfectly out of the box
