Joslinm
Apr 01, 2016Aspirant
wndr3700 very slow wifi
Seems all of a sudden my wireless is quite slow and weak. I get download speeds of 60 mbps wired to the desktop through the router, but only about 10 with wifi. Router is 2 ft away. I looked in the...
- Apr 04, 2016
I was doing download speed testing using Road Runners Residential speed test. Got only 10mbps wireless compared to 60 wired
This is a problem that happenned all of a sudden.
Did a reset and still poor wireless. Tried changing channels a couple times as suggested on various sites. No effect at all. Cell phones would barely connect only 3 ft away from the modem. I think it just wore out
Bought a new WNDR4300 and works perfectly out of the box
Joslinm
Apr 04, 2016Aspirant
ElaineM
Apr 04, 2016NETGEAR Employee Retired
Thanks for the update!
Glad to hear that the new router is working perfectly.
