Ascaris5
Nov 16, 2015Aspirant
WNDR3700v1 wireless throughput half of DIR-825
Hi, First, am I remembering correctly when I think there used to be a dedicated subforum for the 3700? If it is here, I don't see it. It's been years, though; I have had this router a long time...
- Nov 18, 2015
Then it's definitely a hardware failure.
doraemon
Nov 16, 2015Prodigy
Looks like it's starting to fail.
3rd party firmware may help if after reloading the latest firmware didn't fix it.
- Ascaris5Nov 18, 2015Aspirant
I've only had one router fail before (although I currently own 5), and it just stopped working one day-- no lights, no anything. Is this the usual way they fail if they don't just suddenly die?
I flashed the WNDR3700 to DD-WRT, and the wireless speed was even lower than with the stock firmware (about 3 MB/s). I messed with the settings all I could, but I could not get it going any faster. With that in mind, I went back to the stock firmware using the router's recovery mode, and it worked... but the speed was still 3MB/sec.
It does look like its giving all it's got. Even with excellent signal strength and 300mbps connect speed, it's slow. It's even slower in the b/g band, which probably has something to do with all of the other APs using that band around here.
The D-Link is actually working pretty well so far. I don't remember why I switched from it to the 3700; I know the 3700's cpu is about twice as fast, but I can't remember what I was doing (if anything) where that mattered. Or maybe it was unreliable... I don't remember. I've been using the Netgear for a long time!
I do find the onboard setup utility to be needlessly confusing compared to the Netgear version, and the constant logging me out while I am changing settings (and not accepting the changes as a result) is infuriating... but it is much faster than the 3700 on wireless and just as fast on gigabit wired.
- doraemonNov 18, 2015Prodigy
- Ascaris5Nov 19, 2015Aspirant
I think you're right.
I opened the WNDR3700 up... look at these capacitors:
Only one of the four is not visibly bulged.
Ltec caps, Netgear, really? A quality router needs quality parts!
Looks straightforward enough to replace them, though.
