Retep56
Nov 15, 2015Aspirant
wndr3700v2 - NON-2015-0211
I have a vulnerability ID: NON-2015-0211 on my Netgear Router WNDR3700v2, so I need help. I have noticed that there is already repair firmware door others routers, but sadly not for the WNDR3700v2? ...
- Nov 19, 2015
WNDR3700v2 Vulnerability
Hello,I have had some feedback from Netgear about the WNDR3700v2.
This router was declared End of Line (EoL) some time ago, the last firmware released in December 2013, with the SOAP security issue reported 14 months later in 2015.
While this may be a disappointing outcome for you, this approach to EoL products is in line with common business practice for home grade networking devices.
There are steps you can take to ensure that the vulnerability has no impact as described here
Hope that helps.
Andy
Hi Andy,
Why a private message?
In responds of that, yes it is disappointing.
Looking for it - see http://www.netgear.com/landing/eol.aspx - it appears that all the wndr3700 versions have an end of live (EOL). Even the latest version 5.
I understand after reading the text of the url mentioned above, that the risk is limited.
Anyway, thanks for the responds.
Regards
Peter
Retep56
Hello Andy,
Nice such a fast responds:-)
I got the warning Non-2015-0211 from my Avast scanner (new installation).
Searching for that I found this message: WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2000v3
My question is the same and there for related to that message.
In respond of your message I have searched in the Admin of my router. This I found by USB-app. http://readyshare.routerlogin.net/shares for port 80 is activated. Its used for the printer in my homenetwork.
| V | HTTP | http://readyshare.routerlogin.net/shares | 80 |
I noticed that 3700v4 en v5 has "No need to fix"
Does this mean dat the earlier versions does not have "ReadySHARE"?
Will you check it?
Peter
Babylon5
Nov 15, 2015NETGEAR Employee Retired
Yes Peter, I will check with Netgear, but I may not receive an immediate reply since it’s the weekend.
- Retep56Nov 15, 2015Aspirant
Great!!!
No problem, I can wait.
Thanks
Peter
Great!!!
Thanks Andy.
Peter
- applessNov 16, 2015Initiate
I also have Vulnerability NON-2015-0211 on my wndr3700v2. Noticed there's a recent firmware update for other models. Really need new firmware ASAP.
- Retep56Nov 19, 2015Aspirant
Hope that helps.
Andy
Hi Andy,
Regards
Peter
- Babylon5Nov 20, 2015NETGEAR Employee Retired
I find that using the Private Message system can sometimes give me greater scope for dealing with individual issues, if that’s not what you want then fine.
