Retep56
Nov 15, 2015Aspirant
wndr3700v2 - NON-2015-0211
I have a vulnerability ID: NON-2015-0211 on my Netgear Router WNDR3700v2, so I need help. I have noticed that there is already repair firmware door others routers, but sadly not for the WNDR3700v2? ...
- Nov 19, 2015
WNDR3700v2 Vulnerability
Hello,I have had some feedback from Netgear about the WNDR3700v2.
This router was declared End of Line (EoL) some time ago, the last firmware released in December 2013, with the SOAP security issue reported 14 months later in 2015.
While this may be a disappointing outcome for you, this approach to EoL products is in line with common business practice for home grade networking devices.
There are steps you can take to ensure that the vulnerability has no impact as described here
Hope that helps.
Andy
Hi Andy,
Why a private message?
In responds of that, yes it is disappointing.
Looking for it - see http://www.netgear.com/landing/eol.aspx - it appears that all the wndr3700 versions have an end of live (EOL). Even the latest version 5.
I understand after reading the text of the url mentioned above, that the risk is limited.
Anyway, thanks for the responds.
Regards
Peter
Retep56
Great!!!
No problem, I can wait.
Thanks Andy.
Peter
Retep56
Nov 19, 2015Aspirant
Hello,
Hope that helps.
Andy
Hi Andy,
Regards
Peter
- Babylon5Nov 20, 2015NETGEAR Employee Retired
I find that using the Private Message system can sometimes give me greater scope for dealing with individual issues, if that’s not what you want then fine.
- mlenwrdDec 08, 2015Aspirant
I get the same response on my WDNR3700V1.0 and I updated my router to the latest version "
WNDR3700 Firmware Version V1.0.16.98NA GUI Language Version V1.0.0.64 I do not have remote sharing enabled, or my ready share enabled either. I even switched my DNS to "safe DNS" servers.
Avast says they have Hyjacked my router and to upgrade firmware. all the settings I can control are considered safe, so
I need help thanks
Len '[email protected]'
