Geordie
Jan 17, 2016Tutor
WNDR3700v2 attached USB drive is lost to Windows 10 following a reboot
After I reboot my pc running Windows 10, it is unable to reconnect to a WD 500GB USB drive attached to my WNDR3700 router, over both wired (Broadcom Netlink Gigabit Ethernet card) and wireless (Broad...
- Jan 25, 2016
Perhaps that particular computer needs reformat?
Try to back up and format.
doraemon
Jan 18, 2016Prodigy
So when you lose it from your computer, the USB drive is still accessible from your tablet and your Bluray?
If yes, then it could be something on that Windows 10 PC.
You may want to try to scan it for some malwares or have it reformatted.
Geordie
Jan 25, 2016Tutor
I have done a full sweep of the system using ZoneAlarm with nothing found. Since the tablet works okay, I know it is not a fundamental problem with Windows 10. I read some other threads about a similar issue with Windows 8, but did not find a solution there.
Geordie
- doraemonJan 25, 2016Prodigy
