Davee3's avatar
Davee3
WNDR3700V2 DNS resolution
New to this stuff  Have run DNS resolution tests on 2 computers on same router  one says using internal dns  192.168.1.1 & the other a level3 communications server 4.2.2.1 resolvers.level3.net The i...
  • Davee3's avatar
    Davee3
    Oct 18, 2016
    Whoops ! Turns out during a tech mainteanace activity the DNS search was converted from automatic to manual  with 4.2.2.1 as IP . Not sure if this was the cause of delays but highly likely
