Davee3
Oct 10, 2016Aspirant
WNDR3700V2 DNS resolution
New to this stuff Have run DNS resolution tests on 2 computers on same router one says using internal dns 192.168.1.1 & the other a level3 communications server 4.2.2.1 resolvers.level3.net The i...
- Oct 18, 2016
Whoops ! Turns out during a tech mainteanace activity the DNS search was converted from automatic to manual with 4.2.2.1 as IP . Not sure if this was the cause of delays but highly likely
Davee3
Oct 12, 2016Aspirant
Both are windows 10 with all updates allowed automatically DNS assigned automatically Flush? will dig in to how
ElaineM
Oct 12, 2016NETGEAR Employee Retired
You may go to the command prompt and type ipconfig /flushdns then hit enter.
- Davee3Oct 18, 2016Aspirant
