Davee3
Oct 10, 2016Aspirant
WNDR3700V2 DNS resolution
New to this stuff Have run DNS resolution tests on 2 computers on same router one says using internal dns 192.168.1.1 & the other a level3 communications server 4.2.2.1 resolvers.level3.net The i...
- Oct 18, 2016
Whoops ! Turns out during a tech mainteanace activity the DNS search was converted from automatic to manual with 4.2.2.1 as IP . Not sure if this was the cause of delays but highly likely
ElaineM
Oct 12, 2016NETGEAR Employee Retired
You may go to the command prompt and type ipconfig /flushdns then hit enter.
Davee3
Oct 18, 2016Aspirant
