Gamerear19
Mar 08, 2016Aspirant
WNDR3700v2 Dropped connection and other issues
So a few days ago while i was playing a game on my desktop that is connected through ethernet cable the internet disconnected and I had a limited connection. I noticed the blinking green light on the...
- Mar 10, 2016
Perhaps the router is starting to fail.
Try to reflash the firmware of the router, reset then reconfigure.
When you reconfigure, change all the wireless settings to a different SSID and use a stronger wifi password as well as the login password for the router.
Observe your connection.
Gamerear19
Mar 09, 2016Aspirant
No it works fine connected directly to the modem.
2 computers 1 tablet and a game console use the router but i only have 1 device connected at a time so i dont think its an overload issue
I use WPA2 with a 30 character password that has upper case/lower case letters and numbers so its a strong password same with the password to access the settings of the router.
ElaineM
Mar 10, 2016NETGEAR Employee Retired
