matp's avatar
matp
Initiate
Mar 17, 2020
WNDR3700v2 (N600) - Can't change wifi region
This was covered in another topic which is locked I guess to avoid bumping of old threads or consolidating of information about a single topic. https://community.netgear.com/t5/Nighthawk-WiFi-Router...
  • matp's avatar
    matp
    Mar 20, 2020
    Thanks for pointing me in that direction.
    I recall trying telnetenable before without success and as the WNDR3700v2 wasn't listed on the OpenWRT page I assumed it wouldn't work.
    Tried it again and was able to enable telnet and get into the box.
    Since this router has Atheros chipset I used artmtd to set the region (burnsku is for broadcom) to WW (Europe).
    root@WNDR3700v2:/# artmtd -r region
    The region number is: 0x0001
    REGION: NA
    root@WNDR3700v2:/# artmtd -w regionset WW
    argv[3] = WW
    write region number: 0x0002
    Unlocking /dev/mtd/8 ...
    Writing from /tmp/temp.img to /dev/mtd/8 ... [w]
    The region number is: 0x0002
    REGION: WW
    REGION: WW
    I can confirm that the region selection is now enabled and defaults to Europe.
    I can also confirm that this change persists across factory resets and firmware upgrades.
    I am finally able to legally operate this thing.  Thanks again for the nudge in the right direction.
