DR12
Sep 08, 2023Aspirant
WNDR3700v2 router slow to connect to AT&T's modem's internet connection, after the modem has booted
Sorry I don't understand the header requested information, I tried to fill it out but it would not take what I typed. I have a Netgear Router WNDR3700v2 that is slow to connect to my ATT Uverse m...
DR12
Sep 11, 2023Aspirant
One post to two people --- plemans & michaelkenward
Thanks to the both of you for the quick replies
plemans posting
I am now aware of the 2 NAT problem thanks to your reply. I was searching since your reply the last 2 afternoons to refresh my memory & increase my knowledge. I certainly now have a better understanding now.
Option 3 -- Disables the Netgear router’s guest portion I use so that’s not OK.
Option 2 -- Seems like a reasonable choice from your advice but left wondering from my additional research. Which router will still be providing the firewall function and exactly how to option the BGW210-700.
Now thinking the BGW210-700 has an IPforwarding option but no DMZ option which I now believe turns off the firewall on the BGW210 and cures the double NAT problem?
1. Is this correct, Option 2 will also disable the BGW210-700’s Firewall which the WNDR3700v2 will then be doing?
2. Should I be looking at the IPforwarding option in the BGW210-700 to implement Option 2?
michaelkenward posting
My old router, time for a new one is something I have also been wondering about.
3. Do the new routers provide significantly more security over my existing WNDR3700v2 router & BGW210-700 modem/router?
4. Do one or the both of you have any new router suggestions?
a. I noted looking, maybe a year ago, some routers came with lifetime updates too.
Thanks & Sure appreciate your assistance
michaelkenward
Sep 12, 2023Guru - Experienced User
Anything will be more secure than your 13-year old WNDR3700v2.
As to recommendations, try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
