JParez
Jan 05, 2020Initiate
WNDR3700v3 cant find WPS button
Where is the WPS button on this router? (Images will help) Also, what is the difference between the GHz setting and how can I/should I change them to the higher setting? I am trying to set up...
- Jan 05, 2020
Found the answer in the manual!
http://www.downloads.netgear.com/files/GDC/WNDR3700V3/WNDR3700v3_SM_20MAY2011.pdf
JParez
michaelkenward
Jan 06, 2020Guru - Experienced User
Well done. Always a good place to start.
