jgduke
Aug 29, 2015Aspirant
WNDR3700v3 not responding
Hi, I use since 2 and half years a WNDR3700v3 without any problems, since a few days, after one or two hours it stops responding, All LEDs are lit and show activity, but when trying to connect ...
- Sep 03, 2015
there have been reports where Genie causes some problems too.
if you're all good then no need to reinstall the Genie since it's just a tool.
doraemon
Aug 30, 2015Prodigy
reset and reconfigure?
latest firmware?
jgduke
Sep 03, 2015Aspirant
Hi,
lLatest firmware is already installed.
Finally it seems the issue was caused by the Netgear Genie, I had installed it on one of the Laptops in the network.
After having deinstaleld it, the issue seem to have disappeared. Strange tha the issue did not araise earlier as the Netgear Genie was already installed on that laptop since I installed the router in my network. Maybe some incompatibility with the latest firmware.
- doraemonSep 03, 2015Prodigy
