ozee
Jan 17, 2021Follower
WNDR3700v3 slow wifi
Hi there,
Experiencing very slow wifi connection over 2.4 and 5 Ghz. Speed measured using Ookla speed test
Wired from the router: ~295/ 11 Mb
Wifi 2.4G: 3.95 / 1.9 Mb - least corwded channel - 11
Wifi 5G: 24.75 / 12.01 - also using least crowded channel - 161
FW version: V1.0.0.42_1.0.33 ( also tried to roll back to 1.0.0.38 - no improvements)
Tried all the basic stuff like rebooting, trying different devices, different channels, firmware rollback, reset defaults(only with name and security type change), etc.
Security type: WPA2-PSK on both 2.4 and 5 GHz
Bunch of features like readyShare, guest wifi (which actually doesn't work), UPnP, etc are off - only the basic things are on.
Any other suggestions. Did a day of googling tried suggested answered. Funny enough some of them are with status "solved" and the solution was "I bought a new wifi card", or "got R7800" - which are not the things I need,
Anything I'm missing? Why would the speed be so slow?
1 Reply
- olympos1625NETGEAR Employee Retired
Hi Ozee,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. May we know when did the issue start? How long do you have the device? Please DM us the serial number of the router.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
