AllenCohn
Apr 12, 2020Guide
WNDR3700v4: Can I Use Same SSID On 2.4 and 5.0?
Likely this has been asked before, but i can't find it. Apologies about the repeat... I have an old WNDR3700v4. I would like to use the same SSID and password for the 2.4 and 5.0 bands. Would it be ...
- Apr 12, 2020
AllenCohn wrote:Likely this has been asked before, but i can't find it. Apologies about the repeat...
I have an old WNDR3700v4. I would like to use the same SSID and password for the 2.4 and 5.0 bands. Would it be OK for me to do this?
I think that modern routers allow this through a feature called "SmartConnect," but I don't see that in the manual of this old router.
May I simply enter the same SSID and password in the router setup screen?
Thanks,
AllenYou can use the same ssid. its not the same as smart connect as smart connect does band steering. Meaning it moves a device from 2.4ghz to 5ghz based off bandwidth/distance needs. You might have a few issues with older/single band devices while setting up connections to the network. there's also a few other pro's/cons.
http://blog.luxul.com/2018/06/01/should-i-name-my-2-4ghz-5ghz-wireless-networks-the-same/
Apr 12, 2020Guru - Experienced User
Thanks,
Allen
AllenCohn
Apr 12, 2020Guide
Thank you for your thoughtful reply! You solved my problem.
Allen
