Fez2015
Nov 23, 2015Aspirant
WNDR3700v4 cannot port forward 443
Hi I have the above wireless router and i am trying to port forward 443. Every time I try to apply the changes I receive the following message: The specified port(s) are being used by other configur...
- AnonymousNov 23, 2015
Try a reset and another FW version.
Try turning off UPNP and manually forward the ports. I had a 3700v1 and the UPNP option was hosed, tried to add HP HomeServer years ago and even though ports 80,443 and 1443 showed up in the table as ported it wouldn't work until I manually ported them.
Fez2015
Thank for the reply searay. I will try this and report back.
