TimHerbert
Sep 05, 2015Aspirant
WNDR3700v4 constantly dropping wifi signal
I recently changed my modem from an old Comcast-supplied modum because I kept losing my wifi signal. I upgraded to a Motorola/Arris SURFboard modem (SB6141). When the connection works, it works gre...
- Sep 30, 2015
Change the channels on the router by accessing the admin page.
Try channels 1,6 and 11 which are known as non-overlapping channels.
TimHerbert
Sep 13, 2015Aspirant
It worked for a couple of days but I have been unable to maintain a wireless connection for about 24 hours. I can get a wireless signal but I can't keep it for more than about an hour.
ElaineM
Sep 14, 2015NETGEAR Employee Retired
TimHerbert Can you confirm if you have a stable Internet connection when you connect directly to the modem?
- TimHerbertSep 16, 2015Aspirant
Hi ElaineM. Sorry it took so long to reply. Yes, I do. Currenty, I have an internet connection through the ethernet cable from the router, but it is not real stable. Currently, I cannot get a wireless signal even though all the lights on the router indicate that I should. My iphone and laptop can see the network, but cannot get internet connectivity.
Thanks for your help.
- ElaineMSep 17, 2015NETGEAR Employee Retired
TimHerbert I would suggest to reset and reconfigure. Push the reset button the router for 10 seconds and wait for the power light to be stable.
Once stable, configure the router just like it's out of the box. If after resetting the direct connection to the router is not stable, try adjusting the MTU setting on the router. In order to do this, access the admin page of the router then under Advanced > Setup > WAN Setup set the MTU size to 1400. Once done, power cycle the devices then observe the connection.
As for the wireless settings, you should have the wireless settings back to default and be able to connect to it.
Let us know what happens.
- TimHerbertSep 20, 2015Aspirant
I now have an inoperable router. No internet connectivity what so ever. MTU set at 1400 - nothing. MTU set at 1500 (the optimal size according to the method recommended by Netgear support) - nothing.
I believe it is time for a new router. Not a Netgear, but one I can actually count on working.
