66tom
Aug 31, 2016Aspirant
wndr3700v4 constantly loses internet connection
Last week I lost my wired (computer) and wireless (Tablet, phone) internet connections and ever since I have been losing the connection every few minutes. I have reset the router, adjusted the MTU an...
- Sep 07, 2016
Hi Elaine
The Ip address is 10.0.0.1 but the gateway IP address is 10.0.0.138, I ended up ringing my ISP about my issues and since then I haven't had a problem but I did change my plan and am getting a new modem so I'm not sure if that might have changed things.
Thanks for your and searays help hopefully I've got things sorted now.
Tom
Retired_Member
Aug 31, 2016verfiy the ISP connection, bypass router use wired PC
- 66tomAug 31, 2016Aspirant
Hi Searay
Sorry I fogot to put on there that I've done that as well, I had no problem with the connection so I'm not really sure of my next option now.
Thanks
Tom
- Retired_MemberAug 31, 2016
Great,
It sounds like RMA time. I hope you registered it, if not do it first.
Good Luck with it!
- 66tomSep 01, 2016Aspirant
I did luckily, thanks for that Searay
