giannoni
Nov 10, 2020Aspirant
wndr3700V4 does not show the correct date and time
My router does not show the correct date and time . Is there a place where I can set those up ? Many thanks
Nov 11, 2020Guru - Experienced User
I think its under advanced----->security---->schedule.
giannoni
Nov 11, 2020Aspirant
Thank you. Under Advanced/set up/schedule, I only have the possibility to change the time zone, not the date and time. Currently it shows Friday jan 2, 1970
Do you know where the router gets the time ?
- plemansNov 11, 2020Guru - Experienced User
it normally uses the netgear ntp server.
How is the router setup? (modem/gateway)
after setting your time zone, did you click apply?
- giannoniNov 11, 2020Aspirant
The netgear router is set up with fixed IP address connected to a main modem router.
what do you mean by netgear ntp server ?
I have found nowhere to modify the date and time in the admin menu of the netgear router. for you information, it still shows friday jan 2 1970 16:10 : it seems to have started a date and time count when I last reset it 2 days ago. So the start date and time was thrusday jan 1 1969. Weird ?
Many thanks for your help
- plemansNov 12, 2020Guru - Experienced User
if you have it set with a static ip address and going through another router it could be a double nat issue.
