-DC-'s avatar
-DC-
WNDR3700v4 isues with Vizio TV and Netfix
Hello, I just bought a new Vizio TV and when I am playing netflix for less than 30 mins I loose sound and 30 seconds or so later the playback stops. If I used the test netflix connection it errors o...
  • ElaineM's avatar
    ElaineM
    Aug 23, 2017
    As what William10a had mentioned, it could be a router limitation.
    Perhaps, LAN connection is the best route for your situation.
