mugsy56's avatar
mugsy56
WNDR3700v4 ReadyShare access problems in Windows
Hi, I'm hoping someone here can help me. My router WNDR3700v2 recently died and I purchased a replacement WNDR3700v4. I have a WD external drive that worked fine with v2, but I am having pro...
  • mugsy56's avatar
    mugsy56
    Jun 25, 2016
    Thanks, but I've sorted the problem.
    Decided to go right back and do a factory reset because it was probably the only thing I hadn't tried.  This resolved the problem.
    In regard to NAS - I previously had a MyBookWorld NAS storage device and found it to be very troublesome. OK it's a lot faster, but since the drive is mainly used for automatic backups of connected computers, speed wasn't so important as reliability.
